Smeg Pan Stand Parts
Gas Pan Stand Rubber Foot£3.46 As low as £2.76
Genuine replacement pan stan foot rubber or pad to fit the pan or pot stands used in the Smeg built tin gas hob and cooker models as shown or as advised
Smeg Cooker Pan Support£75.55 As low as £48.00
Genuine replacement cast pan support or sometimes called a pan stand to fit a huge range of Smeg oven cooker models as shown
Smeg Pan Support Rubber£2.95 As low as £2.16
Small rubber foot used on the pan supports and other areas of the Smeg gas hobs, ovens and cookers as shown or as advised
Gas Hob Reduction Grill£7.99
Gas reduction grill that allows smaller pots and pans to be used on a huge range of gas hobs, range cookers and gas hob cookers made by Smeg
Gas Hob Reduction Grill£9.95
Gas reduction grill that allows smaller pots and pans to be used on a huge range of gas hobs, range cookers and gas hob cookers made by Smeg with this one usually used on the wok burner
Smeg Cast Iron Wok Stand£34.85
Solid cast iron wok stand to suit many built in gas hob and cooker models by Smeg
Smeg Gas Hob Pan Stand£39.35
Genuine pan stand to suit the models as shown only or only as advised otherwise, please note that this will not fit models not listed or as advised
Smeg Hob Pan Support Foot£3.95 As low as £3.24
Genuine Smeg pan support foot or grid rubber that fits only the models as shown
Wok Burner Adaptor£12.95
Smeg burner adaptor or reduction for the cooker and hob models as shown
Smeg Pand Stand Rubber Foot£2.95 As low as £1.96
Genuine Smeg replacement rubber pan stand foot used ion the hobs and cookers as shown
Finding Smeg spare parts for ovens, cooker and hobs can be hard as they are often very specific to a model or even a production run, even if they look alike and are about the same sizes it doesn't mean that they are correct.
Please see this page for general help in how to get the correct Smeg spare parts that you need.
