Smeg Ignition Generators
For Smeg technical help please use our oven and cooker forum to get free advice from technicians that repair Smeg ovens and cookers.
Ignition Microswitch Set£21.95
Genuine ignition microswitch set with six switches, used on the Smeg cooker and built-in hob models as shown only
Smeg Ignition Button Switch£6.95
Genuine replacement Smeg ignition switch used on the models as shown only
Smeg Cooker Ignition Unit£31.15
Gennuine replacement eight output ignition generator unit used on the Smeg models as shown
Gas Hob Ignition Switch Set£21.35
Ignition switch set used on the Smeg gas hob models as shown only
Ignition Switch Set£22.96Out of stock
Ignition micro switch set used in the Smeg models as shown
Cooker Ignition Switch Set£39.95
Replacement ignition switch set used in the Smeg models as shown only
Gas Hob Microswitch Set£29.75
Ignitions switch set used on the Smeg machines as shown only
Hob Ignition Microswitch Assembly£29.15
Ignition switch set of four switches with wiring to suit the Smeg hob models as shown only
Ignition Earth Cable£2.95
Earth cable for the ignition unit of the built in hob and cooker models by Smeg as shown
Finding Smeg spare parts for ovens, cooker and hobs can be hard as they are often very specific to a model or even a production run, even if they look alike and are about the same sizes it doesn't mean that they are correct.
Please see this page for general help in how to get the correct Smeg spare parts that you need.
