AEG Water Valves
If you are unsure or cannot find the correct inlet valve for your washing machine or washer dryer please contact us to ensure you get the right water inlet valve for your AEG washing machine. We can also often advise if there is a low cost compatible water valve available if required.
Compatible Washing Machine Three Way Inlet Valve£24.95Low cost compatible three way water inlet fill valve to fit AEG and Zanussi washing machine models as listed Learn More
Washing Machine Water Distributor£91.94
Water distributor or detergent dispenser lid to with an integrated water valve fit AEG Lavamat washing machine models
Universal Three Way Water Valve£14.95
Low cost compatible three way water inlet valve that can be used in numerous different washing machines and washer dryers
Universal Three Way Water Valve£11.95Low cost compatible three way water inlet valve that can be used in numerous different washing machines and washer dryers Learn More
Washing Machine Three Way Inlet Valve£69.95Three-way water inlet fill valve with flowmeter to fit the washing machine models as listed only unless advised otherwise Learn More
Washing Machine Fill Valve£51.76
Three way fill valve used on the washing machine and washer dryer models as shown or as advised
Water Inlet Valve£45.55
Genuine replacement tree way water inlet valve to fit the machines as shown and others as directed only
Water Inlet Valve£63.95Three way water inlet valve that incorporates a flow meter so there is no compatible and is only used in the models as shown unless specifically advised otherwise as it is very specific Learn More
Compatible Water Inlet Valve£14.95
Low cost compatible AEG Spares replacement triple water inlet water valve with a special keyed connection block to fit the various washing machine and washer dryer models from AEG as shown
Compatible Washing Machine Water Distributor£44.95Low-cost compatible water distributor or detergent dispenser lid to with an integrated water valve fit AEG Lavamat washing machine models Learn More
Finding AEG washing machine parts can be hard as they are often very specific to a model or even a production run, even if they look alike.
Please see this page for general help in how to get the correct AEG parts that you need.
If you need help to find any AEG Water Valves or any other AEG spare part please ask for assistance as we're only too happy to help you.
