Britannia Ignition Parts
For Britannia technical help please use our oven and cooker forum to get free advice from technicians that repair Britannia ovens and cookers.
Gas Hob Cooker & Oven Ignition Generator£8.95Probably the most common universal ignition block or spark generator unit will generally be found used on double cavity freestanding gas cookers or built in gas hobs and more Learn More
Two Way Gas Ignition Block£39.95
Two output or two way ignition block used on Britannia ovens and range cookers which will usually be the oven ignitor block
Four Way Gas Ignition Block£43.96
Four output or four way ignition block used on Britannia ovens and range cookers which will usually be the hob ignitor block
Britannia Ignition Switch£16.96Out of stock
Ignition switch used on a number of Britannia range cooker models
Gas Ignition Microswitch£12.95
Ignition microswitch usually branded Sabaf used on a number of Britannia range cooker models
Gas Cooker Ignition Microswitch£7.96Ignition microswitch for mounting on the gas tap found on a number of Britannia range cooker models Learn More
Britannia Cooker Ignition Electrode£14.95
1200mm electrode or spak plug and lead to fit a number of Britannia range cookers and ovens made by Ilve
Gas Cooker Ignition Electrode£13.96
800mm electrode or spak plug and lead to fit a number of Britannia range cookers and ovens made by Ilve
Britannia Cooker Ignition Button£7.96
Ignition button used on Britannia range cookers and ovens made by Ilve
Six Way Ignition Block£43.96
Six output or six way ignition block used on Britannia ovens and range cookers.
Finding Britannia spare parts for ovens, cooker and hobs can be hard as they are often very specific to a model or even a production run, even if they look alike and are about the same sizes it doesn't mean that they are correct.
Please see this page for general help in how to get the correct Britannia spare parts that you need.
