Candy Water Valves
This section contains solenoid inlet valves used in Candy washing machines and washer dryers. Many of the water valves will also show as being used in other Candy owned brands such as Hoover among others.
If you are unsure or cannot find the correct inlet valve for your washing machine or washer dryer please contact us to ensure you get the right water inlet valve for your Candy washing machine. We can also often advise if there is a low cost compatible water valve available if required.
Washing Machine Water Valve£31.96
Genuine replacement twin water valve assembly with special keyed connectors
Compatible Washing Machine Water Inlet Valve£8.95
Low cost compatible twin solenoid water inlet or fill valve to fit Beko, Candy and many other washing machine models as shown or as advised
Compatible Washer Dryer Water Inlet Valve£14.95Dual cold fill valve to fit Candy and Hoover washer dryer models including the various models of washing machine and washer dryer listed Learn More
Compatible Water Fill Valve£7.96Compatible cold water solenoid inlet valve to fit the washing machine and dishwasher models listed as well as many others that may not be shown here Learn More
Finding Candy washing machine parts can be hard as they are often very specific to a model or even a production run, even if they look alike.
Please see this page for general help in how to get the correct Candy parts that you need.
If you need help to find any Candy Water Valves or any other Candy spare part please ask for assistance as we're only too happy to help you.
