Search results for: 'cont'
- contact+this
- contact+thi
- contact thi
- contact this
- contact+re
Energy Regulator Invensys MPA-V02-SVC£29.26
Genuine energy regulator used in a number of built in oven and cooker models
Ceramic Hob Heating Element£54.95Replacement 1800W ceramic hob heating element used on the built in ceramic hob and cooker models as shown Learn More
Oven Function Selector Switch£16.79
Genuine oven function or selector switch also known as a commutator switch to fit the built in oven models as shown or as advised as can fit many more models than listed
Top Oven Door Hinge£23.95
Top oven door hinge used on double oven cookers as listed or directed
Oven Function Selector Switch£29.95Main oven function selector switch used on built in oven and cooker models shown or as directed as can fit more models than listed Learn More
Cooker & Oven Cut Out Thermostat£14.95
L70C oven safety thermal cut out thermostat to fit Stoves manufactured built in ovens and cookers as listed
Grill Thermocouple£11.95
Genuine replacement gas oven thermocouple that is used on models as shown or directed
Gas Oven Thermostat£104.95
Oven control thermostat used in the gas cooker models as shown or as directed if your model is not listed
Ignition Generator£42.35
Battery powered ignition generator to fit built in hob models as shown or as instructed as can fit many more models not shown
Oven Inner Door Glass Panel£59.95
Inner door glass panel to fit built in oven and range cooker models as shown
