Search results for: 'mach'
Washing Machine Electronic Control Unit£159.95
Genuine replacement electronic control module to fit the Smeg washing machine and washer dryer models as shown including many integrated or built in models
Washing Machine Fixing Screw£2.75 As low as £2.45
Genuine Smeg Torx type fixing screw used in numerous locations on many washing machine and washer dryer models as shown
Washing Machine Tank Gasket£12.95Genuine Smeg washing machine tank or tub gasket seal to fit the washing machine and washer dryer models as shown from Smeg Learn More
Washing Machine Suspension Damper£9.95Genuine Smeg washing machine and washer dryer suspension leg, shock absorber or damper to fit the various models listed or directed if your model is not shown Learn More
Washing Machine Three Way Water Valve£44.95
Replacement three way water valve or inlet solenoid to fit the Smeg washing machine and washer dryer models shown including integrated models
Smeg Washing Machine Tub Gasket£15.95
Genuine tank gasket or seal to fit he Smeg produced washing machine models as shown or as advised if not listed, colour may vary
Smeg Washing Machine Motor£215.95
Genuine replacement motor used in the Smeg produced washing machine models as shown or only as advised if not listed here
Integrated Washing Machine Push Lock£11.95
Small push/push lock used for the outer wooden door of the integrated washing machine models as shown or as advised only
Washing Machine Water Valve£42.95
Genuine replacement new style triple water valve used on the Smeg models as shown or only as advised
Washing Machine Door Seal£59.95
Genuine washing machine door seal for the Semg models as shown
