- Did you mean
- washing machine spacer in
- washing machine spark in
- Spares for
- Spares+for
- Spares+fa
Washing Machine Tub Seal£15.95Tub gasket to fit washing machines from Servis and other brands produced by Antonio Merloni Learn More
Servis Washing Machine Door Seal Gasket£25.99Door seal gasket to fit Servis washing machine models as listed Learn More
Double Water Inlet Valve£26.95Double fill valve that fits a wide range of washing machine and washer dryer models as listed Learn More
Mains Interference Suppressor£25.96Genuine replacement mains filter or suppressor, sometimes referred to as a capacitor, fits many washing machine and washer dryer models Learn More
Washing Machine Suspension Spring£12.95Top suspension spring used on a number of Servis washing machines as well as many rebranded products as advised Learn More
Washing Machine Switch Set£54.95On off power and function switches x 4 to fit many Ardo Merloni produced washing machines and washer dryers Learn More
Servis Washing Machine Door Seal Band£9.95Door seal clamp band that secures the door seal gasket to the outer drum or tank to fit Servis washing machine and washer dryer models as shown Learn More
Genuine Washing Machine Bearing Set£38.95
Genuine replacement bearing kit to fit the Servis models as shown or as advised
Washing Machine Drain Pump£28.00Replacement water drain pump complete with filter and filter housing to fit the models as shown or as advised Learn More
Washer Dryer Door Gasket Seal£14.95
Washer dryer door gasket seal that fits models of washer dryer from Servis, Hygena, Diplomat and others
