Search results for: 'Contact us'
- contacts
- contact+thi
- contact thi
- contact this
- contact+re
Oven Thermostat£54.95
Dual phial oven thermostat used in the Bertazzoni models as shown only
Oven Commutator Switch£39.95
Genuine four-function plus off selector switch used in the models as shown or only as advised
Oven Lampholder Assembly£29.95
Lampholder assembly with the glass and bulb to fit Bertazzoni models as advised
Bertazzoni 800mm Gas Burner Ignition Lead£19.96800mm ignition lead to fit the burner on the range cooker models as shown or as advised if your model is not shown Learn More
Bertazzoni 350mm Gas Burner Ignition Lead£21.95350mm ignition lead to fit the burner on the range cooker models as shown or as advised if your model is not shown Learn More
Oven Door Hinge Receiver£17.95
Oven door hinge receiver to fit the Bertazzoni oven and cooker models shown or as advised
Delphi Cooker Control Knob£39.95
Coker control knob to fit the Delphi Range of cookers from Bertazzoni and Britannia
Bertazzoni Gas Burner Ignition Lead£29.95
Ignition lead to fit the ultra rapid or largest burner on the range cooker models as shown or as advised if your model is not shown
30cm Oven Door Seal£17.95
Small oven door seal used on the Bertazzoni and Britannia models shown or as advised
