Search results for: 'Washing Machine Parts Can'
- Did you mean
- washing machine part can
- washing machine pass can
- parts for sharp micro # r-1870
- parts i
- parts an
- parts pa
- parts a
Washing Machine Motor£79.96
Main motor for the washing machine makes and models shown or only as advised
Washing Machine Control Module£69.95
Electronic control module used in the washing machine models as shown
Washing Machine Door Lock£15.95
Metaflex door lock used in the machine as show or as advised only
Washing Machine Drive Pulley£21.95
Main drum drive alloy pulley used on large range of washing machine models including the models as shown and others as advised as this pulley will fit more models than are listed
Washing Machine Drum Paddle£6.95 As low as £6.24
Genuine replacement dum paddle or lifter to fit the washing machine and washer dryer models as shown
Washing Machine Sump Hose£17.95
Genuine replacement sump hose that connects from the bottom of the tub to tank of the washing machine to the drain pump housing on the models as shown
Washing Machine Pressure Switch£13.96
Electromechanical pressure switch or water level sensor to fit the washing machine models as shown and others as directed
Washing Machine Mains Interference Filter£16.96
Mains interference or radio filter to suit the washing machine models as shown although this part can be found used on other makes and models not listed
Washing Machine Plastic Drum Lifter£6.95 As low as £6.00
Replacement drum lifter or paddle used ion the washing machine models as shown and others as advised
