Search results for: 'Contact us'
- Contact+us
- contact+this
- contact+thi
- contact thi
- contact this
40cm Gloss Black Outer Oven Door£129.95
Outer oven door for the 40cm door in glass black used on the range cooker models as advised only
Four Way Gas Ignition Block£43.96
Four output or four way ignition block used on Britannia ovens and range cookers which will usually be the hob ignitor block
Britannia Electronic Oven Timer£199.96
Genuine six button electronic timer used on Britannia range cookers and ovens
Dual Zone Oval Ceramic Hob Element£149.95
Oval dual zone 2400/1500 Watt ceramic hob element used on Britannia range cooker models
Dual Zone Oval Ceramic Hob Element£89.95
Oven Door Complete Assembly£378.95
Genuine 40cm oven door complete assembly to suit the small oven door on Britannia cookers
Oven Door Complete Assembly£399.95
Genuine 60cm oven door complete assembly to suit the main oven door on Britannia cookers
Oven Outer Door Glass Panel£125.95
Genuine outer oven door glass panel to suit the main oven door on Britannia cookers
Oven Door 60cm Stainless/Black£699.95
60cm oven door complete to suit stainless steel and black models of range cooker models as advised only
Oven Outer Door Panel Cream£139.96
Outer oven door panel for the 60cm oven on cream range cooker models as advised only
