Search results for: 'Spares+for'
- Did you mean
- spark for
- spacer for
- spares+for+hotpoint+08+co
Outer Grill Door For XG SLX Cream£129.95
Outer grill door panel with glass to suit Classic cream style range cookers as advised only
60cm Oven Door Hinge£16.96 As low as £15.60
Door hinge to fit the large 60cm oven on Britannia range cooker models after serial number 9722001
Britannia Grill Element£51.95
Genuine replacement Britannia grill heating element to fit 40cm ovens
Dual Zone Oval Ceramic Hob Element£149.95
Oval dual zone 2400/1500 Watt ceramic hob element used on Britannia range cooker models
Four Way Gas Ignition Block£43.96
Four output or four way ignition block used on Britannia ovens and range cookers which will usually be the hob ignitor block
Oven Outer Door Glass Panel£125.95
Genuine outer oven door glass panel to suit the main oven door on Britannia cookers
Britannia Electronic Oven Timer£199.96
Genuine six button electronic timer used on Britannia range cookers and ovens
Oven Outer Door Glass Panel£159.95
Britannia Oven Nine Function Control Knob£34.94
Nine function oven control knob to fit Britannia range cookers and ovens
