Search results for: 'Cooker stand'
Oven Rotisserie Assembly£19.96
Genuine Britannia or Ilve replacement rotisserie to suit a number of ovens and range cookers
Oven Door Hinge£19.96 As low as £18.95
Door hinge to fit the large 90cm triple glazed oven door on Ilve and Britannia range cooker models but can be used on some 60cm models also as directed
Oven Minute Minder Clock£39.95
Oven minute minder or manual timer clock used on Britannia and Ilve range cooker models as directed
Oven Inner Door Glass Panel£64.96
Inner oven door glass panel to suit the main 60cm oven door on Britannia cookers
Induction Hob Energy Regulator Switch£23.95
Induction hob energy regulator for Britannia ovens and range cookers
Half Barbecue Griddle£134.95
Genuine Britannia or Ilve replacement barbecue griddle (half) to suit a number of ovens and range cookers
Halogen Lamp Fitting£42.95
Halogen lamp fitting used on Britannia cooker hood models as advised.
Outer Wok Burner Cap£24.95
Replacement outer wok burner cap used on a number of Britannia range cookers as well as Ilve models
Oven Outer Door Glass Panel£159.95
Genuine outer oven door glass panel in gloss black to suit the main oven door on Britannia cookers as advised
Oven Inner Door Glass Panel£62.95
