Search results for: 'genuine'
- genuine tumbler dryer drive belt 1992 h7
- genuine be oven cooker
- genuine+be+oven+cooker
- genuine spare part
- genuine+spare+part
60cm Four Sided Oven Door Seal Gasket£22.94
Genuine four sided oven door seal or gasket to fit many 60cm oven doors on Britannia range cooker models
Oven Outer Door Glass Panel£159.95
Genuine outer oven door glass panel in gloss black to suit the main oven door on Britannia cookers as advised
Range Cooker Control Panel£89.95
Genuine oven control panel assembly in cream colour to suit the range cooker models as shown or as directed only
Small Oven Door Seal Gasket£15.95
Genuine oven top door seal strip or gasket to fit many 30cm oven doors on Ilve and Britannia range cooker models
30cm Four Sided Oven Door Seal Gasket£16.96
Genuine four sided oven door seal or gasket to fit many triple glazed 30cm oven doors on Britannia range cooker models
40cm Four Sided Oven Door Seal Gasket£19.94
Genuine four sided oven door seal or gasket to fit many triple glazed 40cm oven doors on Britannia range cooker models
Oven Door Glass Stop Strip£23.45
Genuine oven door glass panel retaining strip show as item 2 on the diagram to suit the main oven door on Britannia cookers
Britannia Dual Phial Oven ThermostatSpecial Price £36.00 Regular Price £47.50
Genuine replacement dual phial oven thermostat usually used on the main oven in Britannia range cookers as well as other built in ovens and cookers
Oven Lampholder Assembly£19.96
Genuine replacement lamp holder, covering glass and bulb to fit the built-in oven, cooker and range cooker models as shown or only as advised
Britannia Oven Lower Heating Element£41.95
Genuine replacement lower oven heating element to fit the small 30cm oven in Britannia range cookers as shown or as directed if you model is not shown
