Search results for: 'Cooker stand'
Stainless Steel Steam Pan Set£249.95
Stainless steel steam pan set designed to fit on the griddle on Britannia and Ilve range cookers and built in hobs
Oven Outer Door Panel Stainless Steel£199.96
Outer oven 60cm door panel to suit range cookers as advised only
Main Oven Outer Door Full Steel£149.95
Outer oven 60cm stainless steel door panel to suit range cookers as advised only
40cm Glass Door Stop Stainless Steel£19.96
Upper glass door stop used on many range cooker models from Ilve and Britannia for he larger, 40cm wide door
60cm Glass Door Stop Stainless Steel£29.95
Lower glass door stop used on many range cooker models from Ilve and Britannia for he larger, 60cm wide door shown as item 9 on the drawing
Grill Element£59.95
Grill heating element used in cooker as advised, for 90cm Majestic range
Cooker Hood Control Panel£119.95
Control panel to fit the models as shown or as advised only
Cooker Hood Grease Filter£99.95
Genuine replacement metal grease filter to fit the models as shown or as advised only
Range Cooker Control Panel£109.96
Control panel in old white or cream colour to fit the models as advised only
