Search results for: 'Contact us'
- Contact+us
- contact+the
- contact+this
- contact+thi
- contact+te
Compatible Oven Door Seal£27.95
Low cost compatible door seal or door gasket used on Samsung manufactured built in oven models
Cooker Hood Motor Assembly£164.95
Complete motor unit used in the Faber and Rangemaster cooker hood models as shown or as advised
Dual Zone Oval Ceramic Hob Element£89.95
Compatible oval dual zone 2400/1500 Watt ceramic hob element used on Britannia range cooker models
Compatible Washing Machine Door Seal£15.95
Original quality low cost comaptible door seal or gasket used on Vestel produced washing machine makes and models as listed
Cooker Hood Button Assembly£66.76
Button set for the switch assembly used in the models as shown or only as advised
22mm Drain Hose End£6.90 As low as £1.92
22mm drain hose end fitting used on many washing machines and dishwashers
Compatible Ametek Vacuum Cleaner Motor£49.96
Compatibel Ametek motor assembly to suit the Nilfisk cleaner models as shown or as advised
Cooker Hood Fan£61.96
Fan assembly used in the cooker hood makes and models shown and as advised
Cooker Hood Motor Assembly£199.96
Complete motor unit used in the cooker hood models shown or as advised only
Cooker Hood Motor Connector Kit£49.96
Motor connection kit used in the cooker hood models as shown and as advised only
