Search results for: 'lamona'
- Lamona Cooker relay board.
- Lamona,,hja6132 bottom hinge
- Lamona Drawer front bottom
- Lamona fan oven hja 4560 light bulb
- Lamona 3
Compatible Heating Element With Thermistor£14.95Low cost compatible water heating element and thermistor assembly to fit Candy manufactured washing machine and washer dryer models as listed below. Learn More
Compatible Oven Thermostat£34.96
Lower cost compatible oven thermostat to fit built-in oven and cooker models sold under various brand names as listed made by Stoves
Compatible Washing Machine Drain Pump£21.95
Drain pump and filter unit used on the washing machine and washer dryer models as shown or as advised
Compatible Temperature Sensor NTC£7.96
Low cost compatible NTC probe or temperature sensor that detects the water temperature in the washing machine tank assembly using the resistance which alters depending on temperature
Compatible 145mm Rapid Solid Hotplate£35.75
Low cost replacement rapid solid hotplate used on the cooker and built in hob models as shown
Compatible Oven Heating Element£12.95
Lower oven heating element to fit many built in ovens and cookers.
Compatible Fan Oven Heating Element£9.95
Low cost compatible replacement fan oven heating element used in built in oven and freestanding cooker models as indicated or as advised as may fit models not listed
Compatible Oven Door Seal£27.95
Low cost compatible door seal or door gasket used on Samsung manufactured built in oven models
LED Cooker Hood Lamp Assembly£64.96
LED light or lamp unit used in the cooker hood models as shown or as advised only
Universal Compressor Start Run 4uF Capacitor£6.95Low-cost universal start run capacitor used in the produced makes and models as shown, as advised or any that use one with the same specification Learn More
