Search results for: 'direct Cooker Hood Parts '
- Did you mean
- direct cooker hood part
- direct cooker hood pass
Cooker Hood Metal Grease Filter£17.95
One metal grease filter to fit the Elica and other extractor hood models listed but may also be used on other models as directed
Elica Cooker Hood Fan Motor£69.95
One motor unit to fit the Elica extractor hood models listed but will also fit other makes and models as directed
Cooker Hood Lamp Cover£5.95
Genuine replacement cooker hood lamp cover to fit models as directed
Cooker Hood Lamp Cover Rivet£6.35 As low as £3.00
Genuine replacement cooker hood lamp cover rivet that holds the lamp cover in place to fit models as directed
Cooker Hood Metal Grease Filter£18.95
Metal cooker hood filter to fit the models as shown or others as directed
Elica Cooker Hood Metal Grease Filter£39.95
One metal grease filter to fit the Elica extractor hood models listed but may also be used on other models as directed
Elica Cooker Hood Metal Grease Filter£54.95
Cooker Hood Chimney Upper Section£42.95
Stainless steel upper chimney section with the side vents to suit the models as directed
Cooker Hood Grease Filter£21.95
Metal grease filter grid used in the Elica models shown or as directed
Cooker Hood Chimney Lower Section£39.95
Stainless steel lower chimney section with the side vents to suit the models as directed
