Search results for: 'Contact number'
- Contact us
- Contact+us
- Contact you
- Contact+you
- contact+ten
Dishwasher Heat PumpSpecial Price £150.00 Regular Price £185.00
Genuine replacement dishwasher wash motor and heater (heat pump) to fit dishwasher models as listed or directed
Oven Thermostat£42.95
Top or small oven thermostat to fit built in oven and cooker models
Oven Cooling Fan Motor£59.95
Tangential oven cooling fan motor to fit a wide range of built in oven and cookers as shown
Dishwasher Heater Assembly£55.96
Heater assembly mounted onto the main recirculation pump or motor of the models shown or as advised only otherwise
Oven Temperature Sensor£73.96Electronic oven temperature sensor used on the built in oven and cooker models as shown or as advised if your model is not listed Learn More
Oven Door Seal Gasket£31.75
Main oven door seal gasket to fit a wide range of built in oven and cooker models
Dishwasher Heater AssemblySpecial Price £48.00 Regular Price £54.95
Heater assembly with O ring to replace the heating element part of the heat pump unit on the machines as shown or as advised only if not listed
Oven Cut Out ThermostatSpecial Price £21.60 Regular Price £29.95
Oven cut out thermostat to fit the built in oven and cooker models as shown or as directed
Cooker And Oven Glass Lamp Cover£27.95
Replacement lamp cover to fit the makes and models as shown or as advised but please note that the style can alter on this part
Oven Lamp£9.9540W SES 300C long shaped oven lamp to fit AEG and Electrolux oven models as shown or as directed as this bulb fits over two thousand models Learn More
