Search results for: 'mach'
Washing Machine Pump Filter Insert£14.95Genuine replacement drain pump filter assembly to fit the washing machine and washer dryer models as shown or as directed as may fit makes and models not listed Learn More
Washing Machine Mains Suppressor£21.76
Genuine replacement mains interference suppressor to fit a range of dishwasher and washing machine models as shown
Washing Machine Button Cluster£12.95
Button cluster assembly to fit the Candy washing machine models as shown or as directed
Washing Machine Heating Element£33.95Heating element to fit Candy manufactured washing machine models from Candy, Hoover and Iberna Learn More
Washing Machine Drain Hose£14.95
Genuine replacement washing machine drain hose with the special ends to fit the models as shown or as advised
Washing Machine Door Handle£13.96Door handle to fit the Candy washing machine and washer dryer models as shown or as advised Learn More
Washing Machine NTC Probe£23.95
NTC probe or temperature sensor that detects the water temperature in the washing machine tank assembly using the resistance which alters depending on temperature
Washing Machine Bearing Seal£17.75Genuine replacement washing machine & washer dryer drum bearing shaft seal to fit models as shown or as directed Learn More
Washing Machine Program Selector Switch£27.96
Genuine replacement twelve position selector switch for Hoover and Candy models as shown or as advised
Washing Machine Control Module£109.96Control module to fit Candy washing machine models Learn More
