Search results for: 'direct Washing Machine Sp'
- direct vat
Washing Machine Tub Assembly£299.00Complete tub and inner drum assembly used on the models as shown or as directed which includes the bearings and seal Learn More
Washing Machine Tub Assembly£285.96Complete tub and inner drum assembly used on the models as shown or as directed which includes the bearings and seal Learn More
Washing Machine Three Way Fill Valve£61.96Three way fill inlet valve to fit the washing machine and washer dryer models as shown and others as directed Learn More
Washing Machine Bearing Seal£17.75Genuine replacement washing machine & washer dryer drum bearing shaft seal to fit models as shown or as directed Learn More
Washing Machine Pressure Switch£28.75Pressure switch or water level sensor to fit washing machine models as shown and other models as directed Learn More
Washing Machine Temperature Potentiometer£13.45Temperature control potentiometer used on a wide range of washing machines and washer dryers as shown or as directed only if your model is not listed Learn More
Door Seal Clamp Band£16.96
Outer door seal clamp to fit washing machine and washer dryer models as shown or as directed
Compatible Drain PumpSpecial Price £19.56 Regular Price £21.95
Drain pump and filter assembly to fit Hoover and Candy washing machine models as shown or as directed
Cold Water Triple Inlet Valve£29.95
Genuine replacement triple water valve used on a number of washer dryer models as shown or as directed
