Search results for: 'Washing Machine Parts Can'
- Did you mean
- washing machine part can
- washing machine pass can
- parts for sharp micro # r-1870
- Parts
- parts i
- parts an
- parts+an
Motor End Frame And Brush Set£65.95
Genuine replacement motor end frame and brush ring complete with carbon brushes to fit many washing machine and washer dryer models as listed
Motor Inverter Module£229.96
Motor inverter module or power card used on Bosh, Neff and Siemens washing machines as directed only, please check with us that this item is correct for your model before ordering
Washing Machine Drum Spider Bolt Set£31.96Genuine drum spider bolt fixing kit used on models as listed or as directed Learn More
Washing Machine Shock AbsorberSpecial Price £12.00 Regular Price £22.96
Shock absorber to fit the Bosch, Neff and Siemens models as shown or as directed
Washing Machine Soap Dispenser Front Panel£52.49
Genuine replacement front panel to fit the soap dispenser of the Bosch models as shown or only as directed otherwise and please note that this part is very model specific
Washing Machine Bearing Kit£79.25
Genuine bearing replacement kit to fit the Bosch and Siemens models shown or only as advised, pack includes tub screws and seal
Washing Machine Door Assembly£129.95
Complete door assembly to fit the makes and models as shown only
Washing Machine Door Lock£49.96
Genuine replacement door locking mechanism used in the Bosch and Siemens models as shown
Washing Machine Outer Door Trim£54.95
Genuine replacement outer door trim used on the Siemens models as shown only
Aquastop Fill Hose£109.94
Genuine Aquastop fill hose with the double water valve built into it
