- Did you mean
- washing machine spark in
- washing machine spacer in
- Spares
- spares ma
- spares+ma
Motor End Frame And Brush Set£65.95
Genuine replacement motor end frame and brush ring complete with carbon brushes to fit many washing machine and washer dryer models as listed
Bosch Drum & Tub Assembly£237.95
Complete drum and outer tub assembly to fit Bosch washing machine models as shown or as advised if your model is not listed
Aquastop Fill Hose£79.96
Aquastop fill hose and water valve assembly used in the Bosch, Neff and Siemens models as shown or as advised only
Washing Machine Drum Spider Bolt Set£31.96Genuine drum spider bolt fixing kit used on models as listed or as directed Learn More
Washing Machine Outer Door Frame£59.95
Outer door frame used on the Bosch and Siemens models as shown only
Washing Machine Outer Door Trim£54.95
Genuine replacement outer door trim used on the Siemens models as shown only
Washing Machine Soap Dispenser Front Panel£52.49
Genuine replacement front panel to fit the soap dispenser of the Bosch models as shown or only as directed otherwise and please note that this part is very model specific
Washing Machine Detergent Drawer£21.95
Replacement soap dispenser drawer used on Bosch, Neff and Siemens models as shown or only as advised
Washing Machine Outer Door Frame£50.95
Silver outer door frame to fit the Bosch and Siemens models as shown or as advised
Washing Machine Door Handle£29.95
Genuine silver door handle to fit the Bosch and Siemens models as shown or as advised
