Search results for: 'CDA539Fs-2'
Freezer Flap Hinge Bracket Left£4.25
Genuine left hand evaporator or freezer flap hinge bracket to fit fridge freezer and freezer models shown
Freezer Flap Hinge Bracket Right£4.25
Genuine Beko Spares right hand evaporator or freezer flap hinge bracket to fit Beko, Lec, Belling and other fridge freezer and freezer models
Fridge Freezer Control Module£45.85
Electronic control module or PCB used on Beko fridge freezer models as shown or as instructed
Compressor Start Run 4uF Capacitor£14.95
Genuine run capacitor used in the Beko produced makes and models as shown or as advised
Bottom Freezer Drawer Body£15.95
Bottom freezer drawer body without the front to fit the models as shown or only as advised
Glass Fridge Shelf Trim£7.96
Rear shelf trim for models of Beko fridge and fridge freezer as shown or as directed if you model is not shown
Fridge Freezer Control Module£17.56Genuine replacement thermostat control module to fit the fridge freezer models as listed including some integrated models Learn More
Fridge Drain Hole Plunger£3.46Genuine small plastic plunger to clear the drain hole on the rear channel of the various fridge models as shown Learn More
Fridge Freezer Thermal Fuse£16.94
Defrost thermal fuse used in the makes and models as shown
Thermostat Control knob£5.95
Thermostat control knob used in the makes and models as shown or as advised
