- Did you mean
- washing machine spark in
- washing machine spacer in
- Spares
- Spares for
- spares ma
Compatible Washing Machine Drive Belt£6.95Low cost alternative washing machine machine drive belt that also fits several washing machine models Learn More
Compatible Washing Machine Door Seal£21.95
Low cost compatible door seal to fit Indesit SIXL washing machine models that is supplied with the dispenser support included
Washing Machine Drum Assembly£199.96
Complete inner drum and outer tank unit to fit many popular washing machine models from Hotpoint and Indesit
Compatible Washing Machine Pump£14.95
Drain pump to fit the washing machine models as shown or only as advised otherwise
Compatible Washing Machine Carbon Brushes£13.96Set of two low cost compatible carbon brushes to fit NIDEC and Sole ACC motors used in the washing machine models as shown Learn More
Compatible Washing Machine Door Seal£18.95
Low cost compatible replacement grey rubber door seal to fit Indesit washing machine models
Washing Machine Silver Door Handle Kit£6.95
Low cost compatible replacement door handle kit in silver to fit Indesit washing machine models as shown
Indesit Washing Machine Door Assembly£99.95Complete porthole door assembly to fit Indesit washing machine models as shown or as directed Learn More
Compatible Washing Machine Level Sensor£15.95Low cost compatible linear pressure sensor, switch or level sensor to fit the washing machine and washer dryer models as shown Learn More
Compatible Washing Machine Door Seal£16.96Low cost compatible washing machine door seal gasket, without the detergent recovery tube used on some washer models, to fit Ariston, Hotpoint, Creda and Indesit washing machine Learn More
