Search results for: 'direct'
- direct bl
- direct+bl
- direct+part
- direct vat
- direct+vat
6308ZZ Washing Machine Bearing£10.96
Universal 6308ZZ bearing used on models shown or as advised/required
Samsung American Fridge Freezer Water Tank£49.96Water tank assembly to fit Samsung American fridge freezer models Learn More
Main Oven Outer Door Glass£74.95Main oven inner door glass used on built in ovens and cookers produced by Bertazonni Learn More
Liebherr Fridge Freezer Water Filter£82.96
Water filter to fit many newer Liebherr fridge freezer models where the filter is fitted inside the fridge
Fridge Freezer Water Valve£63.55Water and ice water fill valve used on the Samsung American style side by side fridge freezer models from the RSG range Learn More
Intermediate Oven Outer Door Glass£63.95Intermediate oven inner door glass used on built in ovens and cookers produced by Bertazonni Learn More
LG Washing Machine Door Seal Gasket£31.96Door gasket seal, sometimes called a door rubber, to fit LG washing machine models Learn More
Compatible Fridge Thermostat£12.95
Low cost compatible fridge thermostat to fit the models as shown or as advised as can fit more models than listed
Washing Machine Temperature Sensor£4.94
Temperature sensor or thermistor to fit washing machine and washer dryer models
