Search results for: 'direct Washing Machine Pa'
- direct vat
Compatible Washing Machine Pump£17.95
Low cost compatible drain pump to fit the washing machine models as shown or as directed if your model number is not listed
Compatible Washing Machine Door Seal£22.99Low cost compatible door seal or gasket to fit Samsung washing machine models as shown or as directed Learn More
Panasonic Washing Machine Door Interlock£26.63Door interlock switch used on Panasonic washing machine and washer dryer models as listed or as directed Learn More
Washing Machine Drum Paddle Lifter£5.95 As low as £4.14
Low cost alternative to the the genuine replacement plastic drum lifter paddle version 1 to fit the washing machine models as shown or as directed
Compatible Washing Machine Heating Element£13.96Low cost compatible washing machine heating element to suit the machines are shown or as directed Learn More
Compatible Washing Machine Drum Paddle£7.96 As low as £7.20
Low cost compatible drum paddle used on the washing machine models as shown or only as directed
Compatible Washing Machine Door Lock£14.95Door lock to fit the various washing machine models as shown or as directed otherwise Learn More
Compatible Washing Machine Mains Filter£19.96
Low cost compatible Mains interference filter used on the washing machine models as shown or as directed
Compatible Washing Machine Drum Spider£39.95
Compatible replacement washing machine and washer dryer drum support spider to fit the models shown or as directed
Washing Machine Drum Bearing Repair Kit£58.75
Low cost compatible replacement drum spider and bearing repair kit to fit Hotpoint manufactured washing machine models as shown or as directed
