Search results for: 'washing machine dishwashe'
- Did you mean
- washing machine dishwasher
- Washing Machine Drain Pump CWC1410
Washing Machine & Dishwasher 3uf Capacitor£6.46Universal 3uf Capacitor that is used on some models of washing machine and many dishwashers Learn More
Washing Machine & Dishwasher Drain Hose£6.95Universal 1.5m drain hose with 90 degree end fitting, 19mm and 22mm Learn More
Washing Machine & Dishwasher Drain Hose£7.96
Universal 2.5m waste hose with 90 degree end fitting and a 19mm and 22mm diameter hose fitting
Washing Machine & Dishwasher Anti Overflow Valve£4.96Small flap or valve used on the outlet or drain pipe to prevent dirty water re-entering the machine of the models as shown or as directed Learn More
Universal Washing Machine & Dishwasher Y Piece£2.95Washing Machine Hose "Y" Piece Splitter Learn More
Mains Power Switch£5.45
Very commonly used four pole mains power switch to fit the washing machine and dishwasher models shown as well as many others
Washing Machine/Dishwasher Water Inlet Fill Valve£7.96
Universal solenoid fill valve, single 90 degree that will fit most models with a standard fitting inlet valve that is unrestricted
Mains Power Switch£14.95
Mains power on off switch to fit Asko manufactured washing machine and dishwasher models
Compatible Washing Machine Drive Belt£6.95Low cost compatible washing machine & washer dryer belt for the machines as shown Learn More
Washing Machine Mains Suppressor£21.76
Genuine replacement mains interference suppressor to fit a range of dishwasher and washing machine models as shown
