Search results for: 'Pan support'
- Did you mean
- pa support
Pan Support Rubber Foot£7.94 As low as £6.60
Pan support rubber foot (single) used on a number of built in gas hob models as shown or other models and brands as directed
Pan Support Rubber Set£13.96
Set of twelve small rubber feet used on the pan supports and other areas of the Smeg gas hobs, ovens and cookers as shown or as advised
Gas Hob Top Pan Support£19.96Gas hob pan support to fit only the models as shown or as advised, will not fit others unless specifically advised accordingly Learn More
Smeg Pan Support Rubber£4.36 As low as £3.84
Small rubber foot used on the pan supports and other areas of the Smeg gas hobs, ovens and cookers as shown or as advised
Gas Hob Pan Support Rubber Foot£11.15Set of 4 pan support rubber foot used on a number of built in gas hob models as shown Learn More
Gas Hob Pan Support Stand£37.96
Pan support stand used to sit pots and pans onto above the gas burner of the gas cooker and gas hob models shown or as directed
Compatible Pan Support Rubber Foot£1.50 As low as £1.20
Low cost compatible pan support rubber foot (single) used on a number of built in gas hob models as shown or other models and brands as directed
Gas Burner Pan Support Rubber£1.96 As low as £1.56
Gas hob pan support rubber that is used on the built in gas hob and cooker models as shown or as directed as this part can fit makes and models not listed
Gas Hob Rubber Pan Support Foot£22.98
Pack of four pan support feet to fit the built in gas hob and cooker models as shown or as directed as may be found used on models not listed here
Lofra Pan Support£109.96
Gas hob pan stand or support to fit Lofra cooker and oven models shown or as directed as may fit more models than shown
