- Did you mean
- washing machine spark in
- washing machine spacer in
- Spares
- Spares for
- spares ma
Washing Machine Drum Paddle£3.76 As low as £3.00Low cost compatible plastic drum paddle or lifter used on washing machines and washer dryer from Hotpoint and Indesit Learn More
Indesit Washing Machine Door Assembly£99.95Complete porthole door assembly to fit Indesit washing machine models as shown or as directed Learn More
Compatible Washing Machine Level Sensor£15.95Low cost compatible linear pressure sensor, switch or level sensor to fit the washing machine and washer dryer models as shown Learn More
Compatible Washing Machine Door Seal£16.96Low cost compatible washing machine door seal gasket, without the detergent recovery tube used on some washer models, to fit Ariston, Hotpoint, Creda and Indesit washing machine Learn More
Compatible Washing Machine Heating Element£13.96Low cost compatible replacement wash heating element to fit the washing machine and washer dryer models as shown or as directed Learn More
Compatible Washing Machine Thermistor£4.96Thermistor or NTC temperature sensor to fit many different washing machine models Learn More
Compatible Washing Machine Door Seal£22.96
Low cost compatible replacement door seal or gasket to fit the washing machine models as shown
Compatible Washing Machine Door Seal Gasket£13.96Genuine replacement washing machine door seal gasket, boot or bellows seal to fit washing machine models from Ariston and Indesit Learn More
Compatible Washing Machine Drain Pump Filter£4.96
Drain pump filter to fit washing machine models from Hotpoint, Indesit and Ariston
Washing Machine Drive Belt£7.96
Low cost compatible drive belt to fit Indesit and Ariston washing machines and washer dryers
