Search results for: 'aeg l64840'
- AEG Electrolux Favorit 40010VI
- aeg and 1
- aeg a
- aeg an 1
- aeg+an+1
Compatible Washing Machine Water Inlet Valve£15.95
Low cost compatible water valve to fit the washing machine and washer dryer models as shown or as directed as may fit models not listed
Washing Machine Filter Handle£16.96
Replacement filter handle that fits a vast range of Electrolux Group produced washing machine and washer dryers as shown or as advised
Washing Machine Detergent Drawer£45.55
Detergent drawer insert that does not come with the front handle, to fit the models as shown or only as advised otherwise
Compatible Washing Machine Carbon Brush Set£17.95
Low cost compatible replacement carbon brush to fit the makes and models as shown only or as directed but please check that your machine has the Welling motor fitted and not another as these can be altered on production
Compatible Washing Machine Drain Pump£15.95Low cost compatible water drain pump to fit washing machine models as shown Learn More
Compatible Washing Machine Shock Absorber£7.96Compatible low cost shock absorber or damper to fit Electrolux Group models as shown or as directed Learn More
Compatible Washing Machine Door Handle Kit£14.95Low-cost compatible door handle kit to fit the models as shown or as directed Learn More
Welling Motor Carbon BrushSpecial Price £14.40 Regular Price £22.96
Genuine replacement carbon brush to fit the makes and models as shown only or as directed but please check that your machine has the Welling motor fitted and not another as these can be altered on production
Washing Machine & Washer Dryer Tub Seal£18.95Genuine replacement tub seal gasket to fit many plastic split tub washing machine and washer dryer models produced by the Electrolux Group Learn More
Drum Pulley£44.95
Plastic washing machine drum pulley used in the makes and models as shown
