Search results for: 'bulb cover'
- Did you mean
- bulb code
- bell cover
Oven Light Holder Assembly£19.96
Genuine replacement oven lamp or light holder assembly that includes the bulb, glass lamp cover and holder to fit the built in oven and cooker models shown or as directed
Oven Lampholder And Glass Assembly£28.94
Genuine oven lamp holder assembly complete including the glass cover and bulb to fit the oven and cooker models as shown
Oven Lampholder And Glass Assembly£32.35
****LIMITED STOCK ****
Genuine Oven Lamp Glass Fitting Tool£5.24Genuine replacement 63mm lamp glass fitting assembly that allows the lamp cover to be easily removed in order to replace the bulb on built-in oven makes and models as shown Learn More
Oven Lamp Assembly£21.95Genuine replacement lamp unit that is supplied with the glass cover and bulb in the built in oven and cooker models as shown or as directed as can fit other models not listed Learn More
Oven Lamp Assembly£33.95Oven lamp assembly including the lamp or bulb holder, the glass cover for the lamp and a new oven bulb to fit the models as shown or as directed Learn More
Genuine Oven Lamp Assembly£29.95
Complete oven lamp holder with bulb and glass cover to fit the build in oven and cooker models as shown or as advised
Oven Lampholder Assembly£19.96
Genuine replacement lamp holder, covering glass and bulb to fit the built-in oven, cooker and range cooker models as shown or only as advised
Cooker Hood Lamp Repair Set£32.95
Lamp repair set with the glass lamp cover and halogen bulb to suit the models as shown or as advised only, will not fit others
Oven Lamp Assembly£25.96
Genuine replacement lamp holder, glass cover and 40W halogen bulb to fit the cookers shown or as advised
