Search results for: 'direct Cooker Hood Parts '
- Did you mean
- direct cooker hood part
- direct cooker hood pass
Cooker Hood Lamp Cover£5.95
Genuine replacement cooker hood lamp cover to fit models as directed
Cooker Hood Lamp Cover Rivet£6.35 As low as £3.00
Genuine replacement cooker hood lamp cover rivet that holds the lamp cover in place to fit models as directed
Compatible Carbon Cooker Hood Filter£13.96
Genuine replacement carbon cooker hood filter with fixing lugs to fit the cooker hood models as shown or as directed
Cooker Hood Chimney Upper Section£42.95
Stainless steel upper chimney section with the side vents to suit the models as directed
Smeg Cooker Hood Motor£205.96Complete cooker hood motor assembly to fit the Smeg models as shown or others as directed Learn More
Cooker Hood Metal Grease Filter£18.95
Metal cooker hood filter to fit the models as shown or others as directed
Cooker Hood Metal Grease Filter£29.95
Metal cooker hood grease filter to fit the models as shown or as directed as can be used on other makes and models
Elica Cooker Hood Metal Grease Filter£39.95
One metal grease filter to fit the Elica extractor hood models listed but may also be used on other models as directed
Elica Cooker Hood Metal Grease Filter£54.95
D241 Cooker Hood Carbon Filter£15.95 As low as £14.95
Carbon filter to fit a wide range of cooker hood extractor models as listed
