Search results for: 'direct Washing Machine Pa'
- direct+vat
Compatible Washing Machine Water Inlet Valve£15.95
Low cost compatible water valve to fit the washing machine and washer dryer models as shown or as directed as may fit models not listed
Compatible Washing Machine Bearing Seal£4.96Drum bearing seal used on Samsung washing machines as shown or as directed as can fit to many more models than shown Learn More
Compatible Washing Machine Shock Absorber£13.96 As low as £12.95Low-cost compatible suspension leg or shock absorber damper used on washing machine and washer dryer models as listed or as directed Learn More
Compatible Washing Machine Bearing Seal£4.96Low cost compatible drum bearing seal used on Samsung washing machines as shown or as directed as can fit to more models than shown Learn More
Compatible Washing Machine Door Latch£7.75Low cost compatible door latch assembly to fit the models as shown or as directed Learn More
Compatible Washing Machine Door Interlock£12.95Low cost compatible door interlock or safety lock to fit washing machine and washer dryer models as listed or as directed Learn More
Compatible Washing Machine Door Seal£14.95
Low cost compatible washing machine door gasket seal to fit washing machine models as listed or directed
Compatible Washing Machine Filter£12.95
Low cost compatible drain pump filter assembly to fit the washing machine and washer dryer models as shown or as directed
Compatible Washing Machine Carbon Brush Set£17.95
Low cost compatible replacement carbon brush to fit the makes and models as shown only or as directed but please check that your machine has the Welling motor fitted and not another as these can be altered on production
Compatible Washing Machine Suspension Leg£5.95Low cost compatible washing machine suspension leg or shock absorber used on Samsung models as shown or as directed as some models may not be shown Learn More
