Search results for: 'hob pan support'
- Did you mean
- hoo pan support
- hob pa support
Cooker Pan Support Rubber Foot£3.46 As low as £2.40
Rubber type pan support or stand foot used on the models as advised
Rubber Foot Old Style For Pan Supports£3.95 As low as £3.00
Cast Iron Pan Support£179.95
Cast iron pan support to fit E Line and T Line hobs and cookers, please check suitability with us before ordering this item
Fish Burner Cast Iron Pan Support£129.95
Replacement cast iron pan support used only on range cooker and built in hob models as advised
Compatible Pan Support Rubber Foot£1.50 As low as £1.20
Low cost compatible pan support rubber foot (single) used on a number of built in gas hob models as shown or other models and brands as directed
Pan Support Rubber Set£13.96
Set of twelve small rubber feet used on the pan supports and other areas of the Smeg gas hobs, ovens and cookers as shown or as advised
Pan Support Plugs£6.95
Set of four genuine pan support plugs used on the Neff models as shown but may be used on others as advised
Cooker Pan Support£99.95
Cast iron pan support to suit the cooker and hob models as advised only
6" Cooker Ring Element Support£19.96
6" universal cooker hotplate spiral or radiant ring support used on a he number of cooker and hobs
Fridge Bottle Shelf Support Bar£7.96
Support bar for the door shelf on the lower position normally for most of the fridge models shown that holds the items placed on the door panel in place and may fit more makes and models than listed
