Search results for: 'washing machine dishwashe'
- Did you mean
- washing machine dishwasher
- Washing Machine Drain Pump CWC1410
Compatible Washing Machine Drive Belt£6.95Low cost compatible washing machine & washer dryer belt for the machines as shown Learn More
CESET Washing Machine Carbon Brushes£10.96
Washing machine carbon brushes that fit Ceset motors used on many washing machine and washer dryer models and many more than listed here
Dishwasher Drain Hose£6.95
Universal drain or outlet hose 2.5m - 21/22mm and 29/30mm ends to fit most washing machines and some dishwashers
Universal Extendable Waste Water Outlet Hose£6.95
Low cost compatible washing machine and dishwasher drain hose that can be extended from just over a meter in length and 1200mm to 4000mm long with 19-26mm and 26/29mm rubber end cuff connections
Universal 1.5 Metre Waste Water Outlet Hose£3.95Low cost compatible washing machine and dishwasher drain hose that is 1.5m long with 22mm and 30mm rubber end cuff connections Learn More
Universal 2.5 Metre Waste Water Outlet Hose£5.95
Low cost compatible washing machine and dishwasher drain hose that is 1.5m long with 19mm and 22mm rubber end cuff connections
Hanning Drain Pump£26.95Low cost compatible hanning drain pump will fit to a massive range of washing machines, washer dryers and dishwashers Learn More
Anti Vibration Feet£12.95
Pack of four anti vibration feet for use with most washing machine models
Universal Waste Water Outlet Hose£4.96
Universal washing machine and dishwasher drain hose 2m long with 20mm and 30mm rubber end cuff connections and a 90 degree bent end
Universal Askoll 34 Watt Drain Pump£37.96Low cost compatible 34 Watt drain pump will fit to a massive range of washing machines, washer dryers and dishwashers Learn More
