Search results for: 'LSA6145X smeg'
- Did you mean
- lsa6145x, smeg
- lsa6245x, smeg
- Smeg Door Seal - Large Oven Product code: 7541305
- smeg FABS32RCN lower door shelf
- Smeg integrated freezer larder size top drawer fro
- Smeg dishwasher power button model number d1612ca
- SMEG INTEGRATED FRIDGE FREEZER MODEL, UKC3170P
Upper Spray Arm Pipe Gasket£3.95
Small gasket (can be different colours) to fit the top spray arm feed pipe of the Smeg dishwasher models as shown or as advised
Dishwasher Wash Pump Pipe£5.99Replacement pipe or hose that runs from the dishwasher sump to the main wash motor on the Smeg models shown Learn More
Dishwasher Salt Tank Ring£8.95
Plastic ring nut used to secure the salt tank or water softener unit on the Smeg dishwasher models as shown
Dishwasher Pressure Switch£16.99Genuine replacement dishwasher pressure switch to fit the SMeg models as shown but may fit models not listed if advised Learn More
Dishwasher Salt Cap£12.95Genuine replacement dishwasher salt container or water softener cap to suit the Smeg dishwasher models as shown or as advised Learn More
Dishwasher Door Catch£5.75
Wire door lock catch that the door lock mechanism stokes to lock the door to fit the Smeg dishwasher models as shown or other makes and models as advised
Dishwasher Water Softener Gasket Seal£5.95Water softener unit gasket that fits a huge range of Smeg dishwasher models as shown or as advised if your Smeg dishwasher is not listed Learn More
Dishwasher Lower Door Seal£19.96
Genuine Smeg replacement lower dishwasher door seal to fit over a thousand models of dishwasher made by Smeg as shown or as advised
Dishwasher Spray Arm Bush£4.96Small plastic bush that is fitted to the orbital spray arm on the Smeg dishwasher models as shown or as directed Learn More
Dishwasher Spray Arm Support£4.49
Small plastic spray arm support or bush normally used on the lower spray arm of the Smeg dishwashers shown or as directed
