Search results for: 'direct Cooker parts'
- Did you mean
- direct cooker part
- direct cooker pass
- parts for sharp micro # r-1870
- parts i
- parts an
- parts a
D241 Cooker Hood Carbon Filter£15.95 As low as £14.95
Carbon filter to fit a wide range of cooker hood extractor models as listed
Cooker Hood Grease Filter£21.95
Metal grease filter grid used in the Elica models shown or as directed
Cooker Hood Chimney Lower Section£39.95
Stainless steel lower chimney section with the side vents to suit the models as directed
Cooker Hood Chimney Section£43.96
Stainless steel upper or lower (model dependent) chimney section with the side vents to suit the models as directed
Cooker Hood Chimney Upper Section£59.95
Stainless steel upper chimney section to suit the models as directed
Cooker Hood Chimney Bracket£7.96
Cooker hood chimney mounting bracket to suit the Elica models as directed
Cooker Hood Chimney Wall Fixing Bracket£7.96
Cooker hood chimney wall fixing bracket to suit the Elica models as directed
LED Cooker Hood Lamp£219.95
3500K LED lamp unit used in the Elica models as shown or only as directed
Cooker Hood Controls Slider Set£10.96
Plastic slider set used on cooker hood models from Elica as shown or only as directed
Cooker Hood Controls Slider Set£11.95
