Search results for: 'direct Dishwasher Parts B'
- Did you mean
- direct dishwasher part b
- direct dishwasher partit b
- parts for sharp micro # r-1870
- parts i
- parts an
- parts pa
- parts a
Dishwasher Door Handle Lever£9.95
Genuine replacement dishwasher door handle or door lever to fit the Smeg dishwasher models as shown or as directed
Dishwasher Load Ring£4.96
Genuine replacement Smeg load nut sometimes referred to as a ring nut or securing nut to fit the Smeg dishwasher models as listed or as directed
Dishwasher Wash Pump Pipe£5.99Replacement pipe or hose that runs from the dishwasher sump to the main wash motor on the Smeg models shown Learn More
Dishwasher Drain Pump£38.95
Genuine Smeg replacement drain pump to fit the Smeg dishwasher models as shown or as directed
Dishwasher Sump Gasket£7.96
Genuine replacement sump sealing gasket sometimes referred to as a clamp band or drain well gasket to fit the dishwasher models as listed or as directed
Dishwasher Water Softening Unit£44.99
Genuine water softening unit or salt chamber to fit the Smeg dishwasher models as shown or as directed
Dishwasher Control Module£149.95
Replacement electronic control module or PCB to fit the Smeg dishwasher models as listed or as directed if your dishwasher model is not shown
Dishwasher Spray Arm Feed Pipe£13.94
Spray arm feed pipe to fit the dishwasher models, including many build tin or integrated dishwashers as shown or as directed
Dishwasher Spray Arm Support£5.45
Plastic spray arm support that is fitted to the lower spray arm on the Smeg dishwasher models as shown or as directed
Dishwasher Spray Arm Support£4.49
Small plastic spray arm support or bush normally used on the lower spray arm of the Smeg dishwashers shown or as directed
