Search results for: 'hob pan support stand'
- Did you mean
- hoo pan support stand
- hob pa support stand
Thermocouple Support Plate£5.95
The small plate that holds the thermocouple in place, normally for the rapid burner, of the Smeg models shown
Rear Fridge Shelf Trim£9.95
Plastic rear trim or shelf support used on the makes and models as shown and others as advised only
Gas Hob Pan Support£39.95Out of stock
Pan support used on gas hob and cooker models as listed os as directed
Smeg Gas Hob Pan Stand£41.95Out of stock
Genuine replacement steel pan or pot stand to suit the models as shown only unless specifically advised otherwise
Smeg Gas Hob Pan Stand Grip Pin Bushing£2.95Out of stock
Gas pan support grip pin bushing used on the Smeg built in gas hob models as shown and is item 78183 on the drawing
