Search results for: 'Thermocouple hob'
- Did you mean
- thermocouple hot
- thermocouple hoo
- hob stand
- hob+c
- hob+stand
- hob+models
- hob model
Thermocouple Spring£1.96
Small spring used to secure the ignition spark plug on most ignition candles of the Smeg built in hobs, cookers and range cooker
Thermocouple And Ignitor Gasket£2.95 As low as £2.40
Small gasket that sits between the thermocouple and ignition candle of the Smeg built-in gas hob and cooker models as shown
Thermocouple Support Plate£5.95
The small plate that holds the thermocouple in place, normally for the rapid burner, of the Smeg models shown
Smeg Thermocouple Nut£2.95
Thermocouple securing nut used on the thermocouples in the Smeg built in gas hob and cooker models as shown only
Oven Thermocouple£22.96
The 1500mm main oven thermocouple used in the makes and models as show nor as advised
Burner Thermocouple£23.95
Hob burner thermocouple used in the models shown and as advised
Thermocouple Connector£4.96
Thermocouple connector used on Smeg models as advised as part of a modification
Gas Burner Thermocouple£35.95
Gas burner thermocouple used on the built in gas hob and cooker models as shown or as advised only if your model is not listed
Gas Burner Thermocouple£9.95
Replacement 500mm gas burner thermocouple used in the models shown and as directed
