Search results for: 'direct Washing Machine Sp'
- direct+vat
Integrated Washing Machine Door Fixing Pack£69.95
Complete pack to fit the outer wooden kitchen door to the integrated washing machine and washer dryer models as shown or as directed
Washing Machine Door Seal£69.95
Genuine replacement washing machine door seal to fit the models shown but can fit other models from Neff and Siemens as directed including integrated models
Washing Machine Door Lock£49.96
Genuine replacement washing machine and washer dryer door safety lock or door interlock to fit the models as shown or as directed as may for more models than shown including built in or integrated machines
Washing Machine Rectifier Module£54.95Rectifier module or PCB to fit washing machine models as shown or as directed as can fit others but only as directed Learn More
Washing Machine Door Seal Gasket£39.95
Door gasket seal, sometimes called a door rubber, to fit LG washing machine models
Washing Machine Pump Filter Insert£14.95Genuine replacement drain pump filter assembly to fit the washing machine and washer dryer models as shown or as directed as may fit makes and models not listed Learn More
Washing Machine Drain Pump Assembly£29.95
Genuine replacement drain pump to fit the washing machine and washer dryer models as shown or as directed as may fit models not shown
Washing Machine Drain Pump£47.95
Genuine Whirlpool replacement drain pump to fit the washing machine models as show or as directed as may fit other Whirlpool models
Compatible Washing Machine Heating Element£14.66
Low cost compatible washing machine water heating element to fit the various models as shown or as directed as may fit models not shown
Integrated Washing Machine Door Mounting Kit£138.76
Genuine fitting kit including the door hinges to fit a wooden kitchen door to the integrated washing machine and washer dryer models as listed or as directed if your model is not shown
