Elica Control Switches
Various styles of switch assemblies that are used on Elica cooker hood models that control the fan speed settings, lights and mains on-off normally. These parts do tend to be model-specific and can also include the electric control card on which the switches are often mounted.
Many control cards and switch assemblies in a cooker hood are soldered into place and do not use plugs. We do advice of this wherever possible as they will require some DIY skills and a soldering iron to replace the spares.
If you can't find the Elica spares you need or are unsure please contact us for help in making sure you have the correct spares for your Elica cooker hood.
Cooker Hood Controls Slider Set£10.96
Plastic slider set used on cooker hood models from Elica as shown or only as directed
Cooker Hood Controls Slider Set£11.95
Cooker Hood Control Unit£129.95
Genuine replacement cooker hood control switch module assembly to suit the models as shown or as advised
Cooker Hood Switch Assembly£39.95
Genuine replacement switch assembly used in the cooker hoods makes and models as shown only unless advised accordingly
Switch Unit£139.96
Switch unit assembly with wiring to fit the Elica Glass Out cooker hood models as shown
Cooker Hood Control Kit£109.94
Control switch kit including the control module and wiring to suit the cooker hood models shown or only as advised
Control Knob Shaft Pin£5.95
Control knob shaft pin used on the cooker hood models as shown
Cooker Hood Control Switch£52.96
Control switch module or operating unit used in the cooker hood models by Elica as shown
Cooker Hood Control Switches£23.95
Switch unit used in the Elica cooker hood models as shown or as advised only
Finding spare parts for Elica cooker hoods can be challenging as they are often very specific to a model or even a production run, even if they look alike and are about the same sizes it doesn't mean that they are correct.
Please see this page for general parts help in how to get the correct Elica parts that you need for your cooker hood.
If you need help with any Elica spare part please ask for assistance as we're only too happy to help you.
