Neff Water Valves
If you are unsure or cannot find the correct inlet valve for your washing machine or washer dryer please contact us to ensure you get the right water inlet valve for your Neff washing machine. We can also often advise if there is a low cost compatible water valve available if required.
Aquastop Fill Hose£99.95
Aquastop fill or inlet hose used on the makes and models as shown
Aquastop Inlet Hose£66.95
Replacement Aquastop inlet fill hose with built in water inlet valve used on the models as shown only
Washing Machine Inlet Valve£89.95
Genuien three way inlet valve used on the Bosch, Neff and Siemens washing machines and washer dryers as shown or as advised
Washing Machine Water Inlet Fill Valve£9.95
Universal washing machine inlet valve 180 degree twin solenoid to fit most makes and models of washing machine with a standard fitting twin fill inlet valve
Washing Machine/Dishwasher Water Inlet Fill Valve£7.96
Universal solenoid fill valve, single 90 degree that will fit most models with a standard fitting inlet valve that is unrestricted
Dispenser Drawer And Valve Assembly£65.95
Washing machine soap dispenser or drawer assembly complete with the water inlet valves, you cannot get the water inlet valve/s any other way that with this assembly
Aquastop Fill Hose£79.96
Aquastop fill hose and water valve assembly used in the Bosch, Neff and Siemens models as shown or as advised only
Washing Machine Water Valve£59.95
Genuine replacement double water inlet valve to fit washing machines and washer dryers from Bosch, Neff and Siemens
Washing Machine Water Fill Valve£14.95
Low cost replacement double or twin water inlet valve to fit a wide range of washing machines and washer dryers from Bosch, Neff and Siemens
Triple Water Valve£99.95Genuine Bosch Spares replacement triple water valve to fit many washing machine models Learn More
Finding Neff washing machine parts can be hard as they are often very specific to a model or even a production run, even if they look alike.
Please see this page for general help in how to get the correct Neff parts that you need.
If you need help to find any Neff Water Valves or any other Neff spare part please ask for assistance as we're only too happy to help you.
