Smeg Gas Taps
We strongly recommend that these parts are fitted professionally by a Gas Safe registered technician as the gas supply must be interrupted to fit them and the cooker or oven should be fully tested for any leaks after fitting to ensure gas soundness.
Smeg Gas Tap Gasket£2.95
Small shaped gasket or seal that sits between the gas rail and the taps of the Smeg models as shown only
Smeg Grill Gas Tap£49.96
Grill gas tap used on the Smeg oven and cooker models as shown only
Smeg Gas Tap D0.32£49.96
Genuine replacement gas tap used in the Smeg built in gas hob models as shown only
Gas Tap D0.65£35.95
Hob burner gas tap normally for the wok or ultra-rapid burner of the Smeg range cooker and built-in hob models as shown
Gas Valve D0.33£51.95
Gas valve or tap for the small auxiliary burner of the models as shown or as advised
Smeg Gas Tap D0.48£59.95
Gas Tap Magnetic Valve£21.95
Genuine replacement magnetic gas tap valve to fit the modes as shown or as advised
Compatible Gas Tap Magnetic Valve£11.95Low cost compatible replacement magnetic gas tap valve to fit the modes as shown or as advised Learn More
Finding Smeg spare parts for ovens, cooker and hobs can be hard as they are often very specific to a model or even a production run, even if they look alike and are about the same sizes it doesn't mean that they are correct.
Please see this page for general help in how to get the correct Smeg spare parts that you need.
