Smeg Ignition Generators
For Smeg technical help please use our oven and cooker forum to get free advice from technicians that repair Smeg ovens and cookers.
Gas Ignition Microswitch Assembly£23.95
Set of microswitches to operate the gas ignition on the built in Linea hob range and cooker models as shown
Ignition Button£4.31Genuine replacement gas hob and cooker ignition button in black to fit the Smeg models as shown or as directed Learn More
Gas Cooker & Hob Ignition Switch£15.95
Replacement ignition switch to operate the electronic ignition on the Smeg cooker and hob models as shown or instructed
Right Hand Ignition Block£33.95
Right hand ignition block or spark generator to fit the Smeg models as shown or as directed
Ignition Block KitSpecial Price £36.00 Regular Price £39.95Out of stock
Genuine replacement ignition block or unit that now comes as a kit for the Smeg built in gas hob and cooker models listed
Gas Hob & Cooker Ignition Generator£24.95Six way ignition generator to fit a huge range of Smeg gas hobs, cookers and range cookers as shown Learn More
Gas Cooker & Hob Ignition Unit£22.96Genuine Smeg replacement four way gas burner ignition block to fit the Smeg built in gas hob and cooker models as shown Learn More
Ignition Switch Set£28.96
Genuine set of Smeg ignition switches that consists of the five small switches that sit behind the gas control knobs to actives the gas ignition
Ignition Microswitch Set£18.95
Genuine Smeg replacement hob and range cooker ignition microswitch set used on the models as shown
Gas Hob Ignition Switch Set£19.96
Genuine replacement set of ignition microswitches used on the Smeg gas hob models and some gas cookers as shown
Finding Smeg spare parts for ovens, cooker and hobs can be hard as they are often very specific to a model or even a production run, even if they look alike and are about the same sizes it doesn't mean that they are correct.
Please see this page for general help in how to get the correct Smeg spare parts that you need.
